Date/Time: Thu, 06 Mar 2025 09:01:23 +0000
Teton/Edge Clear and Cqg/Amp
View Count: 1072
[2022-01-28 17:43:00]
User675119 - Posts: 13
I currently have an account with Amp/Cqg order routing.
I have just been approved a new account with Edge Clear/Dorman along with Teton Order Routing.
Since I trade Cme, Nymex, Eurex, and Teton does not have Eurex yet, my question is the following:
Can I keep both account with same username for Sierra?
So that if I trade Cme, Nymex I log with Teton , and if I have to trade Eurex I log with Cqg api?
Thank you
[2022-01-28 19:35:36]
John - SC Support - Posts: 38425
Yes, you can do this. You will want to have 2 different installations of Sierra Chart in order to keep things simple. One that connects to the Teton account and the other that connects to CQG.
As long as both installations are on the same computer, you will be able to get the Denali data into both installation without any issues or additional fees.
Refer to the following for how to install another Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
And, in case you do not have it already done, the following links will take you to the Setup Instructions for each trading service:
CQG:
CQG Trading Platform Service: Setup Instructions
Teton:
Sierra Chart Teton Futures Order Routing: Setup Instructions
[2022-01-29 15:54:57]
Marmany - Posts: 308
For info Dorman does not any longer have trading on Eurex. That is why I moved to AMP last year
[2022-01-29 21:27:41]
They no longer support EUREX for any trading platform even including CQG?.
We will have EUREX order routing out we expect in about a month. So if Dorman does support EUREX, they can support it through Teton. They may not support it right away but at some point we would expect they will assuming they do support EUREX through other platforms.
Date Time Of Last Edit: 2022-01-29 21:28:53
