Date/Time: Thu, 06 Mar 2025 08:57:19 +0000
Message Log_Missing ES TPO Chart
View Count: 515
[2022-01-28 16:03:18]
Trading Jules - Posts: 3
Hi There
Please be advised of the message log for your attention. Screen shot attached
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=60553
[2022-01-28 19:11:10]
John - SC Support - Posts: 38425
Keep in mind that a Detached Chart will not show in the list of charts within the Sierra Chart main window. It will show up as a separate program in your Taskbar. So look to see if you can see the chart in your taskbar.
In any case, you can go to the pulldown menu named CW and see if you can see the particular chart you are looking for in there. If so, then select it to bring to the front.
If you are still not seeing the particular chart, then if you can tell us the Chart # or the symbol and time frame, then we can see if it is still in the Chartbook through you Message Log.
Worst case, if you can not find the chart, you can go to a backup copy of your chartbook that had the chart you were wanting. Refer to the following:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
