Date/Time: Thu, 06 Mar 2025 09:11:59 +0000
Candle Separation Graphics
View Count: 586
[2022-01-28 09:31:52] |
Marlin46 - Posts: 34 |
is there a way to make the distance between candles widen and shorten when squeezing down to a time compression? Hope that makes sense. Thanks. Is there a way to make the graphics more precise/refined?
[2022-01-28 18:20:33] |
John - SC Support - Posts: 38425 |
We do not fully understand the question, as they essentially do this already. It is easiest to see for Candlestick bars, but even with OHLC the length of the Open and Close markers changes. If you are looking for something else, please explain a bit more. Is there a way to make the graphics more precise/refined?
The graphics are definitely precise. Everything is setup to ensure that what you see is the reality of the situation. In terms of "refined", that is a matter of taste and not something we will comment on. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-29 11:13:03] |
-When making the candles smaller on the screen they blend together at a point and it is not possibe to see them separately, hence the question is there a way to increase the distance between the candles to remain constant and mathematically scale down in proportion to squeezing the chart down to see a larger time frame on one screen with definded candle visuals. That is all I was asking. Hope that clears up any misunderstanding. Yes or no will be suffiecient. If yes then hoping you would kindly let me know. Thanks. -Thanks in advance for your assistance. As far as refined is concerned to be more accurate is there a way in Sierra to fine tune the display settings outside of the settings on a computer to make the graphics more precise/Hi-def on a smaller scale? Hope that clears it up for you. That was the question I was proposing. Unless a desciption of how to do it was requested, respectfully my intent was to find out if that can be done is all. It would be either yes or no, and then the expectation would be an explanation if yes, and if not then that is just as well with no. Thanks for your help in advance! Appreciate all the help. When I ask it is not personal it is simply requesting information. Seems sometimes the responses are in such a way that it is taken personally. Simply it is requesting information and not personal at all. |
[2022-01-29 20:32:49] |
All of the relevant settings are in the Graphics Settings window: Graphics Settings Look at the Other tab. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
