Date/Time: Thu, 06 Mar 2025 04:11:12 +0000
Drawing bug in v2348
View Count: 594
[2022-01-28 04:20:24]
User100081 - Posts: 19
Hi, 11yr SC user, upgraded from v2331 to v2348, I trade #ES and use the Extending Rectangles for zones that I trade. I use a 3min chart and 2 range bar chart, same chartbook, I have not changed anything with the chart for months. Previously, whenever I would change an Extending Rectangles drawing on Chart #1, it would automatically change on Chart #2, and vice-versa. Since the update, I cannot change the Extending Rectangles drawings on my 2 range bar chart, only the 3 min one even though the identical drawings are on both. However, oddly, if I draw a horizontal line, parallel line, anything OTHER than an Extending Rectangle, it works fine - when I move a drawing on either chart, it moves on the other one. The drawings are not locked, I have gone through every conceivable configuration box trying to sort out why I can’t move Extending Rectangles but I can everything else. When I left click on an extending rectangle on the chart I can’t adjust, instead of getting a drop down menu starting with Chart Drawing Properties, I get Chart Trade drop down menu beginning with Buy Market, since it isn’t even recognizing the ability to adjust the drawing, even though it’s on the chart. Any help would be much appreciated. This might seem like a minor matter, but my entire trading system is based off trading my zones, and therefore I need to be able to adjust them throughout the day. Thanks.
[2022-01-28 05:35:21]
Kiwi - Posts: 375
Hi User100081,
I hadn't realized you could map manual drawings to another chart. Thanks for that!
I'm on 2348 so I just tried it (>> chart >> chart settings >> advanced settings 2 >> copy drawings from chart numbers
And I tried out rectangles, lines, extended rectangles and all worked. I tried moving them and they moved on the copies once the chart update interval passed (check thats not super long??).
So maybe setup a new chartbook & see if it works there. Or send the faulty one to SC.
Date Time Of Last Edit: 2022-01-28 05:35:37
[2022-01-28 05:37:26]
Yes we would not expect there to be any problems with this. It definitely will work correctly. Make sure you are using the functionality correctly:
Copying Chart Drawings from Other Charts Automatically
