Date/Time: Thu, 06 Mar 2025 09:09:01 +0000
DTC to another computer?
View Count: 510
[2022-01-28 02:53:54] |
bdunn - Posts: 19 |
We have the ability to run Sierra Chart on two computers, and other instances of SC. Is it possible to use DTC to send the data to a separate computer that also has an instance of SC running?
[2022-01-28 15:44:01] |
John - SC Support - Posts: 38425 |
Refer to the following: https://www.sierrachart.com/index.php?page=doc/NewInstance.php#InstructionsForSharingDataBetweenSeparateInstalledInstances For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-28 21:49:57] |
No this is not going to work, the exchanges will not allow this. The data can only stay on the same computer.
