Date/Time: Fri, 14 Mar 2025 13:58:10 +0000
VPS and Sierrachart Server Ping Latency!?
View Count: 1895
[2022-01-27 20:22:41]
Mr.DaxF - Posts: 45
Hello dear SC Support,
Dont can find some info about my question somewhere else!!!
i like to buy a VPS on tradingfxvps and like to know how much ping it has with Sierrachart!
both is in aurora - right?
and can somemobdy tell me if this tradingfxvps a good choice?
thank you in advance
have a good day.
Date Time Of Last Edit: 2022-01-27 20:23:28
[2022-01-27 21:58:17]
John - SC Support - Posts: 38653
The only thing we can point you to is the following information:
Data/Trading Service Connection and Symbol Issues: 1.8. Checking Connection Quality to Remote Server by Using Ping
We have marked this as a User Discussion for others to give you their opinions on the VPS choice.
[2022-01-27 22:18:50]
Mr.DaxF - Posts: 45
Ok thank you for quick response!
does SC offer VPS server? As a Service?
[2022-01-27 22:42:45]
Mr.DaxF - Posts: 45
Where are the order and data servers located? | Post: 175321
here you write:
"You can choose whichever one you want to use. The Aurora one will give you latency under a millisecond to the CME."
where i can choose it between cermark and aurora?
[2022-01-27 22:52:38]
That was in relation to our older Sierra Chart Order Routing Service with TT. It is not an issue with our new Teton Order Routing Service.
