Date/Time: Thu, 06 Mar 2025 04:00:54 +0000
Chart ist extrem fast - 5 Candle per Secound
View Count: 527
[2022-01-27 17:57:21]
User928297 - Posts: 2
Helo Sierra,
i trade via AMP and CQG. I'm satisfied so far, but I would also like to use Teton soon, because I believe that the Teton Sierra data feed works better with Teton than with a third-party provider like CQG.
My problem is that I handle the ES with size 2 or 3 range bars. But sometimes the market is so fast that I have up to 5 candles per second or sometimes up to 10. You can't trade that. A friend uses Ninja Continuum and says where I have 2 seconds for a whole movement (candles about 10 pieces), he has 6 seconds and 10 candles.
What I'm saying is his chart is much calmer and slower, but that allows him to trade it.
Solution:
Have switched to intraday data but no change?
What else can I do?
Is the ping time too fast or slow?
I look forward to a solution from you.
Thank you very much.
Marcel Rausch
Private File
[2022-01-27 18:49:11]
John - SC Support - Posts: 38425
If you want to slow down your chart, then you would adjust the "Chart Update Interval" to a higher number. Refer to the information here:
Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu)
As noted in the section linked to above, there is a Global setting for the Chart Update Interval which can be overridden on a Per Chart basis. Try changing this on a single chart first to see if you can get what you want before deciding if you want to apply the change to all charts.
