Date/Time: Thu, 06 Mar 2025 04:17:57 +0000
Keeping P and F charts symbols the same size
View Count: 465
[2022-01-27 17:08:22] |
User794190 - Posts: 26 |
I use Point & Figure charts, set to automatic. How can I (1) keep the X & O symbols the same size and (2) keep the price on the screen. MY PROBLEM: size constantly changes, becoming very large and very small. ALSO, current price - as it increases - sometimes disappears.
[2022-01-27 18:45:02] |
John - SC Support - Posts: 38425 |
To do what you want, you would need to use a "Constant Range" scaling. With Automatic scaling, the system is adjusting the scale up/down to fit all the data onto the screen, which can stretch/compress the X's and O's. With Constant Range, you are setting a specific range so there is no adjusting the scale unless you do it. You will want to review the options for the "Constant Range Scale Modes" to determine which one will work best for you. Refer to the information here: Chart Scale and Scale Adjusting: Constant Range (Scale Range) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
