Date/Time: Thu, 06 Mar 2025 04:07:28 +0000
Problème symbol
View Count: 513
[2022-01-27 15:19:54] |
aurel88 - Posts: 8 |
Bonjour , J'ai un problème avec la plate-forme sierra chart quand je l'ouvre et que je fais find symbol il n'y a plu de symbol c'est tout blanc que dois je faire pour retrouver les marchés ? Je vous remercie |
[2022-01-27 15:39:38] |
We understand you have a problem with File >> Find Symbol and it is blank. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings And then open the File >> Find Symbol window again. Also update Sierra Chart to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
