Date/Time: Thu, 06 Mar 2025 03:54:14 +0000
Standard Sierra Chart (Service Package 3) retrieving ES-202203-G
View Count: 479
[2022-01-27 15:14:00] |
User301688 - Posts: 3 |
Hello, I need to get the symbol S&P500 mini ES-202203-GLOBEX. At this moment I can retrieve it by using an Interactive Brokers demo account but not with a Standard Sierra Chart (Service Package 3). Is there any way how to retrieve this symbol ES-202203-GLOBEX buy using only Standard Sierra Chart Service Package 3 or it is always necessary to use an external Interactive Brokers feed? Thank you
[2022-01-27 15:26:27] |
Yes you can get delayed streaming and historical data for this futures market. Refer to: Delayed Exchange Data Feed The symbol is ESH22-CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
