Date/Time: Thu, 06 Mar 2025 04:29:31 +0000
Switch: TransAct to Stage5/Advantage-change affiliation & login
View Count: 501
[2022-01-27 15:06:42] |
eminimom - Posts: 24 |
Need assistance in changing login to remove affiliation to TransAct as part of my login name since I'm now with Stage5/Advantage. Second, I removed TransAct in the affiliation button. How do I point to my new affiliation, Stage5/Advantage so when I deposit funds to renew to package 10 for Teton/Stage5 I can use them in the Data Settings. Thanks |
[2022-01-27 15:49:48] |
First, paying for Sierra Chart is independent, of what Data or Trading service you are using Sierra Chart with. To use the Teton Order Routing Service just follow the instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions We can change your Sierra Chart username to not have the word Transact_User_ in it. Do you want us to proceed? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
