Date/Time: Thu, 06 Mar 2025 09:23:13 +0000
Top of book level near last price bar
View Count: 651
[2022-01-27 14:42:06] |
Mark_47 - Posts: 27 |
Is there a way to view the top levels of the DOM near the last price bar? For example "stick" to the CURRENT PRICE LINE study. (I have attached an image as an example of what it should look like). |
[2022-01-27 17:38:49] |
John - SC Support - Posts: 38425 |
The only item that has a way to do this is the Market Depth Historical Graph, but it's a lot of overhead just to get the information displayed as you are wanting. With the Market Depth Historical Graph, you would want to set the following Inputs: - Show Quantity Numbers: Only After Last Bar - Display Market Depth Quantities After Last Bar: Yes - Depth Quantity Type to Display After Last Bar: Last Depth - Percentage of Fill Space to Display Market Depth Quantities Rectangles In: 10 (you can adjust this to your preference) Set other items as desired. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-28 07:52:45] |
Thank you John as allways. If I can give some advice, a study like the one attached in the photo could be interesting. Horizontal histograms for N levels of the DOM close to the last price (with also the quantities per level of course). Good day and good work. Date Time Of Last Edit: 2022-01-28 07:54:11
[2022-01-28 12:46:41] |
1+1=10 - Posts: 270 |
@Mark_47 … SC has the feature in your picture: Trade Menu: Draw DOM Graph on Chart (Trade menu)
[2022-01-28 19:48:53] |
Yes, but in the SC it is fixed on the right side of the screen, while the one in the image attached is near to the closing price of the last bar.
