Date/Time: Tue, 26 Nov 2024 04:24:08 +0000
SendBracketOrder not working after order entered on charts
View Count: 1014
[2014-04-10 14:02:57]
User33552 - Posts: 23
I have experienced that in SIM mode, when I enter an order from the charts:
1. It does not send the bracket order I have selected in the DOM
2. When I do to the DOM and choose SendBracketOrd it does not send
[2014-04-10 16:47:18]
Are you referring to Send Attached Orders specifically as is documented here:
https://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html#SendAttachedOrders
We need to know the specific procedure you are following.
And are you referring entirely to Sierra Chart or to some other program?
