Date/Time: Tue, 06 Oct 2026 01:18:38 +0000
Volume by Price using RTH/ETH. The POC/VAH/VAL run down to the next profile - very ugly
View Count: 4773
| [2022-01-27 13:28:11] |
| knarf01 - Posts: 49 |
I figured out to configure my Volume By Price study using "Multiple Profiles Based on Fixed Time". I then set my chart settings to have RTH 0930-1559, ETH 1600-0929. I select the option that draws the POC/VAL/VAH/VWAP but those lines do this weird line that connects them to the next periods VAH/VAL/POC - VWAP seems to be functioning normal for some reason. I tried using Line - Skip Zeros as the style but that didn't help. POC/VAH/VAL all should be drawn independently for the next profile. In my screenshot I used a white box to outline specifically what I mean. Any help is greatly appreciated. |
| Attachment Deleted. |
| [2022-01-27 17:20:32] |
| John - SC Support - Posts: 48114 |
Set the Subgraph Draw Style for those items to Dash, rather than Line. Refer to the information here: Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-01-29 19:04:25] |
Hi John, thanks for the response.. That did not work at first but when I came back to it later to make sure all the settings were right it did! Thank you!
