Date/Time: Thu, 06 Mar 2025 04:12:01 +0000
Display active Trade Window Configuration name over Chart
View Count: 573
[2022-01-27 09:50:35] |
User665177 - Posts: 1 |
Is there a way to display active Trade Window Configuration name over a Chart as a plain text Study or Chart Header Field? In some scenarios it might be useful to see current configuration without having to open Trade Window where the value is normally seen at the top in the dropdown. Especially when custom Trade Window Configuration buttons are used to switch between different configurations and Trade Window is not always open. |
[2022-01-27 16:15:57] |
John - SC Support - Posts: 38425 |
There is not a built-in way to do this. It could be done by creating a custom study. Refer to the information starting here: Advanced Custom Study Interface and Language (ACSIL): Introduction If you want to hire out for the work, you will find a list of programmers here: https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
