Date/Time: Thu, 06 Mar 2025 03:52:25 +0000
Trading with several accounts
View Count: 724
[2022-01-27 07:58:37]
User437588 - Posts: 69
Hello
I have an account with AMP with a separate trading account number that is capitalized. But use the real time data from you through another account.
How can I now trade live and access the AMP account with the data connection from you?
[2022-01-27 15:53:14]
John - SC Support - Posts: 38425
We are not sure exactly what you are asking, but you can definitely use Sierra Chart with the Denali Exchange Data Feed and trade through your desired trading service. For more information on this, refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
Since you are with AMP, you would most likely be setup with CQG for your order routing. If this is correct, then you would follow the instructions at the following link to connect your Sierra Chart to your CQG account:
CQG Trading Platform Service: Setup Instructions
