Date/Time: Sun, 20 Sep 2026 03:45:39 +0000
heikin-Ashi
View Count: 1109
| [2022-01-27 03:36:13] |
| User841161 - Posts: 348 |
Added Heikin-Ashi Chart to chart #1 which is an inverted chart (multiply -1) which is an inverted chart of #4. But not displaying as a Heikin-Ashi chart. https://www.sierrachart.com/image.php?Image=1643254262927.png |
| [2022-01-27 15:15:37] |
| John - SC Support - Posts: 47939 |
Sorry, but your image and your statement are conflicting. We see that Chart #4 has the Heiken-Ashi study and looks like a Heiken-Ashi chart. Then we are not sure what Chart #1 is exactly and how you got it. If you duplicated Chart #4 and then used the "Multiply Bars by -1" study, then you should get the bars showing properly, but inverted. It looks like you have chart #1 set to display as "Line on Close". Check "Chart >> Graph Draw Type" to see what it is set to for that chart. You may just need to set it to Candlestick. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
