Date/Time: Thu, 06 Mar 2025 03:58:28 +0000
SIM Trade Data Feed
View Count: 580
[2022-01-26 21:27:50]
User737477 - Posts: 19
Hi guys,
I've recently paid for the Denali exchange data but I've yet to activate the data itself because the live account isn't actually funded yet - I'm looking at the DOM and its OK that the data is delayed until the account is funded, but the performance of the DOM is pretty bad - I mean that it doesn't update seamlessly, choppy action etc the depth volume doesn't change seamlessly etc. I'm obviously missing something but until I have the account funded [this week], I need the following:
1) SIM trading ability
2) Doesn't matter if its delayed data or not;
3) Good DOM performance.
How do I achieve this please?
Thanks for your help
Alun
[2022-01-26 22:14:34]
John - SC Support - Posts: 38425
1) Use the Trade Simulation mode that is built into the system. By default, you are in this mode. Refer to the following:
Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes
2) You have the delayed data for now.
3) There is a lot that can go into this. But the first thing is to see if this is just a perception issue. We want you to change the Chart >> Chart Settings >> Advanced Settings >> Chart Update Interval to a lower number like 200. See if this update setting is more of what you are looking for.
Otherwise, refer to the information at the following link:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
