Date/Time: Sun, 20 Sep 2026 21:12:10 +0000
Volume Profile Bars - size
View Count: 1038
| [2022-01-26 16:57:23] |
| Steve Leon - Posts: 319 |
I notice that that on my TPO chart that size or length of the volume profile bars on a volume by price study for TPO is not proportional to the total volume for different sessions For example. The volume profile in my overnight session for ES has longer/larger bars that my RTH volume profile even though the total volume may be significantly higher in the RTH session I assume that the bars are calculated relative to the individua sessions profile Is there a way to display the volume bars relative to the total volume between sessions so that if the volume in a bar in than rth session is greater than that of an overnight session it will appear larger on the rth session ? Thank you Steven Leon |
| [2022-01-26 17:38:51] |
| John - SC Support - Posts: 47939 |
Refer to the following input for the Volume by Price study: Volume By Price Study: Volume Profile Bars Length Relative to All Visible Profiles For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-01-26 18:54:32] |
Thank you
