Date/Time: Mon, 05 Oct 2026 08:17:06 +0000
Backtesting control panel doesn't seem to be available
View Count: 874
[2022-01-26 16:52:02]
PanCSI - Posts: 9
Hi.
I am trying to backtest a custom study in SierraChart and I can't seem to be able to.
When I usually test a study, I have a control panel that allows me to select a start and end date, increase or decrease the speed of the backtesting, pause and other options.
I am not sure if I am missing some configuration step here, if something changed in a recent application update, but I no longer see the control panel.
I believe that the text of the options in the menu has changed but I am not sure. Currently I am trying to use "AutoTrade System Replay Backtest", within the Trade menu.
I have also gone to Chart > Replay Chart > Replay Chart to open the control panel (which I assume includes the controls I am looking for), but the control panel does not show up.
Without it, I can't select the timeframe I want to backtest nor to play and pause. This seems to have changed after an update, I had no issues before, but it might be something else that I changed inadvertently.
Looking forward to your reply.
Best regards,
Miguel
[2022-01-26 17:28:18]
John - SC Support - Posts: 48095
Refer to the following:
Replaying Charts: Chart Replay Window Not Visible
