Date/Time: Thu, 06 Mar 2025 04:28:42 +0000
Subscription Package for Proprietary Funding Data
View Count: 518
[2022-01-26 16:51:51] |
ScalpRule - Posts: 4 |
Hello, I am using Rithmic from a proprietary trading firm. Is there a specific subscription package that I would need to allow me to trade using the proprietary trading firms Rithmic data access? Thank you, |
[2022-01-26 17:27:21] |
John - SC Support - Posts: 38425 |
Yes, you need to be on Package 10, 11 or 12 in order to use Sierra Chart with Rithmic. Just be aware of the issues with Rithmic data as outlined at the following link: Rithmic Trading Platform Service: Rithmic Support Policy We strongly suggest using our Denali Exchange Data Feed for your data. Refer to the following: Denali Exchange Data Feed If you do not already have a separate trading account in order to qualify for the non-professional CME Group exchange fees, then we recommend the following: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-27 14:50:07] |
So I can use Denali feed but connect and submit orders to a Rithmic based account?
[2022-01-27 15:04:27] |
Yes you can. This is explained here: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
