Date/Time: Thu, 06 Mar 2025 03:58:55 +0000
Connecting issue
View Count: 437
[2022-01-26 16:51:30]
User966676 - Posts: 4
I can’t connected to data fed with my package 11.
I need help
[2022-01-26 17:22:57]
John - SC Support - Posts: 38425
You need to go through all of the Setup Instructions for the particular exchange for which you want the data. For the CME Group data, you would go through the instructions at the following link:
If you are wanting data for EUREX or CFE, then the instructions are on the same page as above, just scroll to the top and find the link for the setup instructions for the exchange you want.
