Date/Time: Thu, 06 Mar 2025 04:12:50 +0000
Copper Spread
View Count: 476
[2022-01-26 15:43:48] |
User841161 - Posts: 249 |
Brought up HGU22(SEPCOPPER)-HGZ22(DECCOPPER)spread, don't understand the y axis values. It seems like market should be around .024 on y axis.. https://www.sierrachart.com/image.php?Image=1643211711351.png |
[2022-01-26 16:07:52] |
We will check on this.
[2022-01-26 21:02:45] |
This is a price multiplier issue. Update the symbol settings following these instructions: Global Symbol Settings: Update Global Symbol Settings After that apply them to the chart following these instructions: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
