Date/Time: Thu, 06 Mar 2025 04:21:15 +0000
Bad tick filtering of equities data
View Count: 497
[2022-01-26 15:17:25] |
User100912 - Posts: 104 |
How do I fix these? Delete and redownload doesn't correct it, and there's too much manual work correcting the records individually as explained here. Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.3 Method to Filter out Intraday Chart Data Errors The issue is present on many symbols. |
[2022-01-26 16:00:19] |
These are not bad ticks but actual trades. It is an extraordinarily difficult process to determine what specific trade types to filter out and then there are always consequences when we do that. So we are not going to be doing any further effort on this with this existing data feed. This is not going to be an issue with our new NASDAQ feed which also provides data for AMEX symbols. This new data feed will be out in February. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-26 16:09:46] |
What we can do though do is edit out, these out of range values. We will have a look for this symbol.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-26 16:09:52
