Date/Time: Wed, 16 Sep 2026 23:54:09 +0000
how to enter symbol for Preffered Stocks
View Count: 1030
[2022-01-26 14:01:02]
The Stealthy Trader - Posts: 190
Thanks in advance
[2022-01-27 02:07:58]
Sierra_Chart Engineering - Posts: 24877
You can find the symbols here:
https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks
[2022-01-27 15:10:25]
Hi, so although I was able to find a couple of Preferred Funds listed under the NYSE(where it trades), the one I'm interested in Crestwood Equity Partners Preferred wasn't shown.
On Ameritrade the symbol is CEQPp but every platform has different ways of displaying preferred stock symbols.
Again, this isn't a regular stock symbol like for this one it's CEQP..it's the lower case p that indicates it's a preferred stock symbol.
If you don't have it presently can I request it being added?
TIA
[2022-01-29 02:15:10]
With our new NASDAQ data feed available next week it looks like this is going to be the symbol:
CEQP--NQTV
[2024-07-31 19:00:50]
$tack - Posts: 123
I'm trying to follow this thread and don't see how preferred symbology works. There are also warrants and other asset types that should come with the US stock data. I can't seem to get a symbol list for that from sierra chart. Please advise
[2024-07-31 20:10:24]
We do not know the symbol format. You actually have to search for the symbols to find what you need:
File Menu: Searching for Stock Symbols
For example perform a search for the symbol BAC and you will see the preferred stocks listed for it.
BAC
BACA
BACK
BACpB
BACpE
BACpK
BACpL
BACpM
BACpN
BACpO
BACpP
BACpQ
BACpS
Date Time Of Last Edit: 2024-07-31 20:11:03
[2024-09-03 14:05:46]
Hi, I'm getting delayed data today even though I made a bunch of payments in last few days..
What am I missing here?
Thanks,
Jon
[2024-09-03 14:28:16]
For US equities? Your account is set to receive real-time data. Please restart Sierra Chart and enable Force Login:
Sierra Chart - Software Login Instructions: Forced Login
Date Time Of Last Edit: 2024-09-03 14:28:26
[2024-09-03 15:45:03]
$tack - Posts: 123
I had done this in chart settings. The confusion came because the search functionality only showed up under Consolidated Tape(Delayed/Realtime) option but there was another option above it that said Consolidated Tape but had no search feature. Not sure why I have the 2. Anyway I assumed the search feature didn’t exist when I didn’t see it in the first one
