Date/Time: Sun, 24 Nov 2024 15:54:56 +0000
Indication on Trade Window when Trading Locked is enabled
View Count: 740
[2022-01-26 13:36:22] |
User624476 - Posts: 33 |
Hello, Currently it is barely noticeable when Trading Locked is enabled. The additional "[Lock]" text on the chart is not noticeable. Please add a highly visible indication directly to the Trade Window: eg. disable the buttons, add a highly visible "LOCK" message, trade window background color (similar to the graphic option when SIM is enabled), etc etc. |
[2022-01-29 00:25:24] |
User379468 - Posts: 508 |
+1
[2024-05-07 02:43:32] |
user_xyz - Posts: 416 |
I was looking for a way to color the background in the chart window when [Lock] is enabled. Is this available yet? It's barely noticeable and when using multiple instances of SC. I'm trying to get a faster visual cue then trying to read if Lock is present on every chart header. Thanks! |
[2024-05-09 21:59:55] |
John M - Posts: 171 |
I use a RED color and make the Trade Lock button large with full text on the Control Bar. Its state is quite visible at a glance and it's easy to implement. |
[2024-05-09 22:11:39] |
Thanks I have that too however the control bar button doesn't have a two color state for on/off. It's like red and shaded red. Unless something has changed?
[2024-05-21 19:50:58] |
https://github.com/pwr-shift/Sierrachart-Trading-Locked-Status-Display
