Date/Time: Tue, 26 Nov 2024 04:47:31 +0000
chart drawings
View Count: 1023
[2014-04-10 09:48:32] |
EuropeanTrader - Posts: 290 |
Hi, is it possible to copy chart drawings (also for different symbols since I use quote board link to change the symbols on that exact chart) to a different chart that is in sepparate chart book? thx |
[2014-04-10 10:06:50] |
No, but you can duplicate a chart to another Chartbook. Refer to the Chart Menu documentation for instructions. This should indirectly accomplish what you want.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-10 10:07:01
