Date/Time: Thu, 06 Mar 2025 03:57:29 +0000
Chart DOM Issue when changing symbols
View Count: 598
[2022-01-26 11:41:41] |
Yuri_T - Posts: 20 |
I made a chart layout that I needed with ES symbol (Denali datafeed, Rithmic real-time datafeed). And then I wanted to use it for 6E futures, copied it and changed the symbol. All went well apart from the fact that I cannot place orders at 0.00005 values from chart DOM. When I try, the order jumps to closest 0.0001 value either up or down. The same stuff for chart trading. Placing orders from R Trader platform does not have this issue. Any suggestion on how to resolve this?
[2022-01-26 14:56:39] |
You need to apply the correct Symbol Settings to the chart. Instructions: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
