Date/Time: Thu, 06 Mar 2025 03:56:27 +0000
Target & Breakeven Stop Los
View Count: 704
[2022-01-26 11:22:34]
neubecklifestyle - Posts: 9
Hi, just want to know how to setup a Trade with Stop to Breakeven and Target 1 & 2.
I read all the infos about it but not really understand it.
The Plan:
Order with 1 Lots for example
Target 1
Target 2
and Stop.
So thats easy OK, but i want that when Target 1 hits or execute then put all stops tp breakeven.
[2022-01-26 15:55:53]
John - SC Support - Posts: 38425
An example of what you are stating you want can be found here:
Attached Orders: 2 Targets and Common Stop with Move to Breakeven on First Target
But, it does not sound like this is really what you want, as it is not possible to have 2 targets with a quantity of 1. It sounds like you want a single target, but the move to breakeven to happen at a particular spot. In this case, follow the setup that we pointed you to above, but remove the first target. So you will have just one target and one stop and the stop will have the Move to Breakeven that you want.
[2022-01-27 12:52:41]
That’s exactly what I want, thanks!
