Date/Time: Tue, 26 Nov 2024 16:18:22 +0000
[Locked] - last traded price skipping on DOM
View Count: 1245
[2022-01-25 21:57:04] |
User729614 - Posts: 7 |
My last trading price columns skipping about 30% of values. Please see attached files First screen shot made from my account Second screen shot (with explanations) from my school lesson. So, my DOM skipping some values while school's DOM has every single value. Please, help |
Screen Shot 2022-01-25 at 1.48.45 PM.png / V - Attached On 2022-01-25 21:52:14 UTC - Size: 2.07 MB - 199 views Attachment Deleted. |
[2022-01-25 21:58:40] |
Second screen shop (School)
Screen Shot 2022-01-25 at 1.53.04 PM.png / V - Attached On 2022-01-25 21:58:01 UTC - Size: 1.8 MB - 173 views |
[2022-01-26 14:59:25] |
John - SC Support - Posts: 36300 |
The time shown at the top of your chart is 16:48:45 and we see that you are in the United States, so you are looking at the evening session, which is much less traded. So it would not be unusual to see the kind of activity that you are for the evening session. Still, make sure you have the correct columns displayed. We assume you want the "Current Traded Bid/Ask Volume". Check the way the data is flowing this morning when the instrument is active and see if you still have the same issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-26 16:37:24] |
No. I'm talking about "last traded size market orders" columns. Those columns located at the left and at the right side along "current price" in the middle. Between "Current price" and "Current Traded Bid/Ask Volume". I showed that column with cursor on the screen recording and marked with red arrows on screen shot. By compering my chart with chart provided from school live, I have reason to believe that those empty spots are actually missing numbers which my system skipping for some reason. |
Private File Attachment Deleted. DOMDOM.png / V - Attached On 2022-01-26 16:37:06 UTC - Size: 1.93 MB - 163 views |
[2022-01-26 16:38:35] |
File attached
Private File |
[2022-01-26 16:55:59] |
There are no such columns as "Last Traded Size Market Orders". We need to know exactly what the columns are that you are referencing in order to understand what you are seeing. If you are not sure exactly what the names are, then go to Trade >> Customize Chart/Trade DOM Columns to see the list of columns. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-26 17:11:53] |
Thank you for that tip. Correct name: Recent Bid/Ask Volume |
[2022-01-26 17:33:34] |
Never mind, I found that settings. My problem was that I couldn't find correct name for that column. Thank you for helping me! |
[2023-11-09 14:35:18] |
blazemk - Posts: 4 |
If I may ask what fixed your issue? I have the same issue with Recent Bid/Ask Volume that you were facing. I am not sure if Sierra support is still following this thread but did not want to create a duplicate post.
Recent bid ask volume.png / V - Attached On 2023-11-09 14:33:55 UTC - Size: 116.18 KB - 72 views |
[2023-11-09 14:53:04] |
Sierra_Chart Engineering - Posts: 17182 |
This is an old thread and we have now locked it.
