Date/Time: Thu, 06 Mar 2025 04:25:57 +0000
Making verticle grid lines visible
View Count: 518
[2022-01-25 21:44:44] |
User554580 - Posts: 11 |
Hello, How do I make verticle grid lines visible in my chart window? They are currently not visible, even though I selected "Verticle grid" in the "Chart" menu. See screennshot. Also, is it possible to set these grid lines to a single timeframe? For example, have them set so that they always mark 30 minutes increments. Thank you! Julien |
![]() Attachment Deleted. |
[2022-01-25 22:00:04] |
Refer to the Vertical Grid documentation here: Chart Menu: Vertical Grid (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
