Date/Time: Thu, 06 Mar 2025 04:27:56 +0000
Use chart values tool to show values of a specific bar
View Count: 619
[2022-01-25 21:35:31] |
User554580 - Posts: 11 |
Hello, Is it possible to use the chart values tool to show the values of the single, specific bar selected by the tool? The way my software is currently configured, the chart values at the top of the window only appear to show the values of the last bar in the window. See screenshot. Thanks, Julien |
[2022-01-25 21:57:05] |
Yes for this you need to use the Tool Values Window: Window, CB and CW Menus: Tool Values Window (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
