Date/Time: Thu, 06 Mar 2025 09:05:08 +0000
Hi, I'm waiting on the brokerage to open my account
View Count: 532
[2022-01-25 17:52:40] |
User165219 - Posts: 10 |
Can I get a trial run for 15 days with CME exchange enabled?
[2022-01-25 17:54:55] |
Are you at least receiving the delayed streaming data at this time for the CME Group symbols?
[2022-01-25 18:39:08] |
yes, I have delayed, but I'm after live
[2022-01-26 14:43:51] |
In this case, you will need to wait until you have your live funded trading account. Or you have to pay the higher priced professional exchange fees. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-26 18:23:12] |
The broker says you are able to provide me access straight away as a free trial. I wouldn't ask if the broker had not have mentioned. |
[2022-01-28 19:09:50] |
This is not something we are able to do. We can provide you delayed streaming data at this time.
