Date/Time: Thu, 06 Mar 2025 19:13:46 +0000
Partial data on intraday chart
View Count: 584
[2022-01-25 17:37:31]
User275592 - Posts: 97
my intraday chart does not display the datas from the time i close sierrachart to the start of the session
If i close sierrachart at 5 pm Paris time, the data from 5 pm to 11 pm (the closing of the market) are not displayed when i restart sc the day after
I verified the setup which i did not modify
I tried to visualize the data on rtraderpro and every thing is ok
Thank you for your help
[2022-01-25 19:08:09]
John - SC Support - Posts: 38447
You are using Rithmic, therefore refer to the following:
Rithmic Trading Platform Service: Rithmic Support Policy
Also, it looks like you are using the older Rithmic connection. You should really update to the latest release and then use the new Rithmic connection. To use the new connection, you would follow these instructions:
Rithmic Trading Platform Service: Setup Instructions
[2022-02-10 16:57:31]
i am using rithmic direct - dtc Is this the good one ?
[2022-02-10 17:11:51]
Yes that is what you need to be using.
