Date/Time: Tue, 26 Nov 2024 04:19:27 +0000
[Locked] - Sierra Chart Google Search!
View Count: 9605
[2014-04-10 02:49:58] |
We have put back the Sierra Chart Google search and it can be accessed here: https://www.sierrachart.com/index.php?l=doc/GoogleSearch.php This provides a more advanced searching capability than the search that was recently added to replace it. The ads from the Google page will be removed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-10 02:51:13
[2014-04-10 10:25:44] |
Also the top of the support board you will see a link named View My Post/Threads. It can be accessed here: https://www.sierrachart.com/SupportBoard.php?do=MyPosts This will list links to all of your posts and the threads you have posted in, for easy reference. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-10 10:25:59
[2014-04-14 02:02:48] |
The ads have now been removed from the Google search.
