Date/Time: Wed, 27 Nov 2024 10:26:14 +0000
[User Discussion] - Create horizontal Grid Lines from excel or text file
View Count: 1722
[2022-01-25 17:14:13] |
User202227 - Posts: 12 |
Hello team, i had like to leverage a file similar which has some levels information on ES and i had like to draw horizontal lines on the chart is there way to automate this ? i am not sure how do it as i can have the text file in a excel format as well if that provides more options.. thank you so much for the support Thanks sai yeluri |
[2022-01-25 19:03:13] |
John - SC Support - Posts: 36309 |
There is not an automated directly available within Sierra Chart. You can create a custom study that does this for you. Refer to the information on custom studies starting here: Advanced Custom Study Interface and Language (ACSIL): Introduction Or, if you want someone to develop it for you, then here is a list of potential programmers: https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-20 16:05:55] |
Zorin - Posts: 19 |
Just for fun - here is how you do it [cpp file + levels] Note: it's very draft + done from the default ACSIL study, really slow [as it uses subgraphs instead of drawings], but main problem - how to read the data - you'll get an idea from that If I'll have some free time - I'll try to re-code it using actual "horizontal lines" objects [instead of subgraphs] |
zHorLines.cpp - Attached On 2022-05-20 16:01:57 UTC - Size: 4.12 KB - 287 views zLevels.csv - Attached On 2022-05-20 16:02:47 UTC - Size: 630 B - 329 views |
[2022-05-29 14:57:50] |
Zorin - Posts: 19 |
Added another version - using drawings instead of sub-graphs [much faster]
zHorLines.cpp - Attached On 2022-05-29 14:57:11 UTC - Size: 4.94 KB - 288 views zLevels.csv - Attached On 2022-05-29 14:57:32 UTC - Size: 829 B - 315 views |
[2023-08-19 14:27:55] |
Ed C. - Posts: 117 |
Thanks very much for posting this! I've been trying to find time to write this myself...
[2023-08-19 15:42:24] |
gcUserStudies - Posts: 106 |
This may also help as a reference. Copies from google sheets. https://github.com/FrozenTundraTrader/sierrachart/blob/main/google_sheets_importer.cpp |
