Date/Time: Thu, 06 Mar 2025 04:17:33 +0000
TPO Cryptocurrency Glitch
View Count: 471
[2022-01-25 16:12:14] |
User141757 - Posts: 2 |
Hello, I'm having an issue with how TPO is being displayed. Seems I'm only getting it with certain markets. The issue is that I can load a cryptocurrency pair fine, but then as soon as I change the tick size, everything disappears and I'm left with just a single session like in the image attached. Any way to sort this out? Thank you |
![]() Attachment Deleted. |
[2022-01-25 18:58:24] |
John - SC Support - Posts: 38425 |
Can you please get us a copy of that chart showing the problem you are having by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-26 17:17:29] |
Hi John, Thanks for getting back to me. Seems I have resolved the issue for now simply by hitting 'delete all data and download'. Thank you |
