Date/Time: Thu, 06 Mar 2025 08:56:15 +0000
Compact tool values window include Regions 1 and 2
View Count: 546
[2022-01-25 16:07:07] |
User14953 - Posts: 243 |
Is there a way to show information from chart Region 1 and chart Region 2 in the same compact tool values window? The current configuration requires that the cursor be placed over chart Region 1 to see that info and then move the cursor to chart Region 2 to see that information. Better would be a configuration that would allow including information from chart Regions 1 and 2 in the same compact tool values window regardless of cursor location. |
[2022-01-25 17:56:29] |
John - SC Support - Posts: 38425 |
This is not supported in the Compact Tool Values Window. But, you can see the information for all regions using the Tool Values Window. Refer to the following: Chart Drawing Tools: Tool Values Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-29 16:53:50] |
Unfortunately that option eats up too much screen real estate and comes with 'babysitting chores' when working with several products and timeframes. I sure like the way Chart Settings >> Advanced Settings >> Values to Display checkbox window allows the user to conveniently Select Only the values desired which enables display within a Minimal Screen Footprint. If the Scope of Values included in that checkbox window were to include those from Region 2 and maybe Region 3, that would be a beautiful thing. |
