Date/Time: Mon, 23 Nov 2026 13:15:16 +0000
voice alerts
View Count: 1481
[2022-01-25 15:58:20]
coachted - Posts: 545
I purchased the ability to have a voice alert and created it but I dont see it in my sounds can you please advise where it would be.
[2022-01-25 17:54:20]
When you created the Text to Speech sound file you should have received a pop-up notification that it had been saved. Did you get this notice?
The location where these are stored is in the "AlertSounds" folder, which is under the Main Sierra Chart installation folder (typically C:\SierraChart). Look for the file in that location which will be named the same as the text that you entered (i.e. if you entered "Hello this is a test", then the sound file will be named "Hello this is a test.wav".
[2022-01-26 18:58:42]
found it thank you
