Date/Time: Thu, 06 Mar 2025 04:11:23 +0000
Historical data only supported with Sierra data feed
View Count: 706
[2022-01-25 15:03:15]
JoshuaVrijbergen - Posts: 2
Why do i get this this notification?
"Historical data only supported with Sierra data feed"
I have Interactive Brokers connected to Sierra Charts.
In the past i could see the intraday charts of the EUREX.
But now i got this notification while loading a EUREX index.
[2022-01-25 16:27:06]
To access EUREX data from any source, you need to be using Sierra Chart Service Package 10 or higher. See below for instructions to change this to package.
And then we recommend using the EUREX data provided by the Denali Exchange Data Feed instead of Interactive Brokers. Information and instructions:
Denali Exchange Data Feed: Introduction
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
Date Time Of Last Edit: 2022-01-25 16:27:33
