Date/Time: Thu, 06 Mar 2025 16:17:10 +0000
DATOS EN REAL
View Count: 494
[2022-01-25 15:02:57] |
User853036 - Posts: 3 |
He contratado el paquete de servicios 11 y en la plataforma no tengo datos en real. Qué debo hacer?
[2022-01-25 17:32:12] |
John - SC Support - Posts: 38440 |
From Google Translate: I have contracted the service package 11 and on the platform I do not have real data. What should I do?
You have not activated any exchanges for the Denali Exchange Data Feed. For the CME Group data, you can activate the exchanges at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-09 03:34:39] |
Instructions: Denali Exchange Data Feed: Activate the Exchanges: The CME Group (Denali Exchange Data Feed Setup Instructions) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
