Date/Time: Thu, 06 Mar 2025 03:30:15 +0000
4 instances + spreadsheet for trading not responding as expected!
View Count: 459
[2022-01-24 18:48:59] |
User185210 - Posts: 66 |
Hello, I have 4 sub-instances and have the following issues: 1/ when I enter a position from one sub-instance the spreadsheet for trading study is only working if I entered the position from the same sub-instance where the study is located. I would like to have it working even when the position is entered from another sub-instance for the same traded symbol. Is it possible? 2/ My keyboard shortcuts (to move the stop up or down...) does only function if the position has been taken from the same sub-instance where I entered the position. Is that the normal behaviour or is there a way to have it working on all sub-instances for the same symbol? Thank you for your help, Cheers, Paul Paul |
