Date/Time: Thu, 06 Mar 2025 04:28:14 +0000
Vol Profile for current session
View Count: 504
[2022-01-24 18:45:14]
12VMan - Posts: 45
I want to have a volume profile for the session (e.g. 9:30a - 4p ET for ES) on the right side of the chart. When I try to set this up, however, it is showing volume from more than just the current session. I've attached screenshots of my settings
Date Time Of Last Edit: 2022-01-24 19:06:30
image2022-01-24 12_25_27-Study Settings_ VBP - Session Start to E.png / V - Attached On 2022-01-24 18:44:17 UTC - Size: 44.67 KB - 131 views
image2022-01-24 12_26_06-Study Settings_ VBP - Session Start to E.png / V - Attached On 2022-01-24 18:44:24 UTC - Size: 49.24 KB - 134 views
image2022-01-24 12_26_33-Study Settings_ VBP - Session Start to E.png / V - Attached On 2022-01-24 18:44:31 UTC - Size: 50.57 KB - 124 views
[2022-01-25 15:44:37]
John - SC Support - Posts: 38425
What you have set should just give you the most recent day session. What makes you think you are getting data from more than that?
[2022-01-25 19:12:12]
12VMan - Posts: 45
When the new session starts (e.g. 9:30a) the profile is built out based on prior activity.
