Date/Time: Thu, 06 Mar 2025 03:18:14 +0000
Trans Act
View Count: 656
[2022-01-24 18:28:08]
User725704 - Posts: 15
Please help me get this straight. IF I have SC with Trans act with Infinity futures. If I switch to your Denali data feed I can still use Infinity futures as my broker?
[2022-01-24 19:16:30]
Stage 5 Trading - Posts: 155
Dear Trader,
As a former Infinity Broker I fully understand the trials and tribulations of changing brokerage firms. As far as I understand, the Transact connection is in the process of no longer being supported by Sierra Chart. Stage 5 takes great pride in helping Transact/Infinity traders transition as seamlessly as possible. Denali would be the data feed you would use for real time and historical data and Sierra Chart Teton Order Routing would be your order routing solution. This is all maintained by Sierra directly, which I feel provides great benefits to traders as Sierra can focus on enhancements instead of maintenance of other third party order routing feeds. In addition, I feel it is the best overall quality and value for traders.
If you are ready to move to the Teton Order Routing solution right away, we invite you to file an application here: https://stage5trading.com/
Please feel free to contact us and we will gladly assist you with the process of transitioning and hopefully helping you improve your current issues.
If you have questions or would like to speak to an assigned personal broker for details, please call us at 312-896-9897 or 1-800-258-6675. You can email us at sierrachart@s5trading.com and can also contact us here: https://stage5trading.com/contact/
Thank you,
Anthony Giacomin
Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results.
[2022-01-24 19:32:17]
Regarding the prior post, this is true, we do want users to move off of Transact because that is a system that is considered a legacy system which we are phasing out. Refer to:
*Important* Priority Message to Transact Users
Date Time Of Last Edit: 2022-01-24 19:32:58
