Date/Time: Tue, 08 Sep 2026 15:58:19 +0000
Can't figure out why Stop moving to Break Even
View Count: 1184
[2022-01-24 16:48:03]
User585019 - Posts: 27
I'm in sim trading two contracts. I use an OCO and have never set an automatic breakeven setting.
For some reason that I can't figure out, one of the contracts has its stop move to break even shortly after entering the trade.
There is nothing in the trade window that says move to breakeven.
Under Targets, Move to Breakeven for Stop is greyed out.
Under Set, Move to BE Offset is set to 0 ticks, the default.
Under General Trade settings and Chart Trade settings I didn't see anything selected that would generate a move to BE automatically.
I'm not sure what kind of info you need to diagnose the problem, but I'm happy to send logs or a screenshot. Or if you can tell me where else to look.
It's strange, because this has never happened before, so I wonder if a setting changed by accident or when I downloaded the newest version there's a new default I'm unaware of.
It's also strange because only one of the two contracts does this.
TIA for your time.
[2022-01-25 14:20:52]
You need to just check the Trade Activity Log for the reason:
Trade Activity Log: Viewing Historical Trade Activity
You will see the reason in the Order Action Source field for the line for the order modification.
Date Time Of Last Edit: 2022-01-25 14:21:11
[2022-01-28 17:23:06]
So I've opened the Trade Activity Log and gone under the Order Action Source as suggested. However, I don't see anything that would suggest why one contract had it's stop automatically move to break even.
This is from a trade taken on SIM today in MCL.
I bought 2 contracts using a standard OCO bracket. No auto breakeven settings used.
As you can see, price moved up and at some point that I can't figure out, after price moved in my direction, the stop of just one of the contracts moved to break even and I was stopped out as price retested the entry level.
I've bolded part of the 3 Trade, which was the break even stop, to show you what I'm seeing.
Under Order Action Source all it says is:
Trade simulation fill. Big: 87.75 Ask 87.76 Last 87.75
As mentioned in the original ticket, this automatic behavior only happens with one of the contracts.
Please advise where to look and what to do to have just a normal OCO bracket with a target and stop that don't automatically move.
TIA
ActivityType  DateTime  TradeAccount  Symbol  BuySell  Price  OrderType  InternalOrderID  Quantity  Price2  OrderStatus  ServiceOrderID  OrderActionSource  FillPrice  FilledQuantity  OpenClose  ParentInternalOrderID  PositionQuantity  FillExecutionServiceID  HighDuringPosition  LowDuringPosition  Note  AccountBalance  ExchangeOrderID  ClientOrderID  TimeInForce  Username
Fills  2022-01-28 11:18:00.123985  Sim1  [Sim]MCLH22_FUT_NYMEX  Buy  87.75  Limit  305  1    Filled  305  Trade simulation fill. Bid: 87.74 Ask: 87.75 Last: 87.75  87.75  1  Open    1  305.1      MCL 2c.twconfig  0.00      Day
Fills  2022-01-28 11:18:00.124161  Sim1  [Sim]MCLH22_FUT_NYMEX  Buy  87.75  Limit  308  1    Filled  308  Trade simulation fill. Bid: 87.73 Ask: 87.75 Last: 87.75  87.75  1  Open    2  308.1      MCL 2c.twconfig  0.00      Day
Fills  2022-01-28 11:34:21.664315  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.75  Stop  307  1    Filled  307  Trade simulation fill. Bid: 87.75 Ask: 87.76 Last: 87.75  87.75  1  Close  305  1  307.1  88.19  87.63  MCL 2c.twconfig  0.00      Day
Fills  2022-01-28 11:53:50.608906  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.41  Stop  310  1    Filled  310  Trade simulation fill. Bid: 87.45 Ask: 87.46 Last: 87.41  87.45  1  Close  308    310.1  87.75  87.38  MCL 2c.twconfig  0.00      Day
[2022-01-28 19:32:06]
John - SC Support - Posts: 47798
You need to look at the Orders in the Trade Activity Log (not the Fills) to see what the source of the Move to BreakEven was.
Refer to the following for how to change the filters in the Trade Activity Log:
[2022-01-31 14:38:40]
Ok, so just on that one transaction with 2 contracts, here is what the Orders say:
One line jumps out at me, I'm repasting here on its own, because it does indicate that somewhere there is an auto-trail command. However, when I check the Trade Window for the Chart settings, I don't see where that would be set.
Orders  2022-01-28 11:20:07.144162  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.41  Stop  307  1    Pending Modify  307  Auto trail order modification. Move to breakeven. Trigger price: 87.87. Using LastModifyQuantity of 1. Using new provided price. Requested Price: 87.75. Requested Quantity: 1      Close  305  2        MCL 2c.twconfig  0.00      Day
All orders
Orders  2022-01-28 11:17:59.257911  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.15  Limit  306      Pending Child-Client    MCLH22_FUT_NYMEX/MCLH22_FUT_NYMEX [CBV][M] 3 Min #8 | User order entry | Last: 87.75 | AO=1. Attached Order | Client side OCO order      Close  305          MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:17:59.273773  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.55  Stop  307      Pending Child-Client    MCLH22_FUT_NYMEX/MCLH22_FUT_NYMEX [CBV][M] 3 Min #8 | User order entry | Last: 87.75 | AO=1. Attached Order | Client side OCO order      Close  305          MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:17:59.294634  Sim1  [Sim]MCLH22_FUT_NYMEX  Buy  87.75  Limit  305  1    Order Sent    MCLH22_FUT_NYMEX/MCLH22_FUT_NYMEX [CBV][M] 3 Min #8 | User order entry | Last: 87.75 | AO=1      Open            MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:17:59.322505  Sim1  [Sim]MCLH22_FUT_NYMEX  Buy  87.75  Limit  305  1    Open  305  Simulated order accepted      Open            MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:17:59.322551  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.35  Limit  309      Pending Child-Client    MCLH22_FUT_NYMEX/MCLH22_FUT_NYMEX [CBV][M] 3 Min #8 | User order entry | Last: 87.75 | AO=1. Attached Order | Client side OCO order      Close  308          MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:17:59.343082  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.55  Stop  310      Pending Child-Client    MCLH22_FUT_NYMEX/MCLH22_FUT_NYMEX [CBV][M] 3 Min #8 | User order entry | Last: 87.75 | AO=1. Attached Order | Client side OCO order      Close  308          MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:17:59.369219  Sim1  [Sim]MCLH22_FUT_NYMEX  Buy  87.75  Limit  308  1    Order Sent    MCLH22_FUT_NYMEX/MCLH22_FUT_NYMEX [CBV][M] 3 Min #8 | User order entry | Last: 87.75 | AO=1      Open            MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:17:59.385998  Sim1  [Sim]MCLH22_FUT_NYMEX  Buy  87.75  Limit  308  1    Open  308  Simulated order accepted      Open            MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:00.123984  Sim1  [Sim]MCLH22_FUT_NYMEX  Buy  87.75  Limit  305  1    Filled  305  Trade simulation fill. Bid: 87.74 Ask: 87.75 Last: 87.75  87.75  1  Open            MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:00.124042  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.55  Stop  307      Pending Child-Client    Updating move to breakeven stop reference price on parent modification/fill to 8775      Close  305          MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:00.124050  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.55  Stop  307      Pending Child-Client    Updating move to breakeven stop trigger price on parent modification/fill to 8787      Close  305          MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:00.124063  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.15  Limit  306  1    Order Sent    Auto-sent child from parent fill      Close  305  1        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:00.124077  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.55  Stop  307  1    Order Sent    Auto-sent child from parent fill      Close  305  1        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:00.124103  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.15  Limit  306  1    Open  306  Simulated order accepted      Close  305  1        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:00.124113  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.55  Stop  307  1    Open  307  Simulated order accepted      Close  305  1        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:00.124160  Sim1  [Sim]MCLH22_FUT_NYMEX  Buy  87.75  Limit  308  1    Filled  308  Trade simulation fill. Bid: 87.73 Ask: 87.75 Last: 87.75  87.75  1  Open    1        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:00.124203  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.35  Limit  309  1    Order Sent    Auto-sent child from parent fill      Close  308  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:00.124219  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.55  Stop  310  1    Order Sent    Auto-sent child from parent fill      Close  308  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:00.124242  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.35  Limit  309  1    Open  309  Simulated order accepted      Close  308  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:00.124251  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.55  Stop  310  1    Open  310  Simulated order accepted      Close  308  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:02.620303  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.55  Stop  307  1    Pending Modify  307  MCLH22_FUT_NYMEX/MCLH22_FUT_NYMEX [CBV][M] 3 Min #8 | User order modification. Requested Price: 87.41. Requested Quantity: 1      Close  305  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:02.620345  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.41  Stop  307  1    Open  307  Simulated order modify complete      Close  305  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:04.861307  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.55  Stop  310  1    Pending Modify  310  MCLH22_FUT_NYMEX/MCLH22_FUT_NYMEX [CBV][M] 3 Min #8 | User order modification. Requested Price: 87.41. Requested Quantity: 1      Close  308  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:04.861356  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.41  Stop  310  1    Open  310  Simulated order modify complete      Close  308  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:07.410374  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.15  Limit  306  1    Pending Modify  306  MCLH22_FUT_NYMEX/MCLH22_FUT_NYMEX [CBV][M] 3 Min #8 | User order modification. Requested Price: 88.84. Requested Quantity: 1      Close  305  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:07.410408  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.84  Limit  306  1    Open  306  Simulated order modify complete      Close  305  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:11.487849  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.35  Limit  309  1    Pending Modify  309  MCLH22_FUT_NYMEX/MCLH22_FUT_NYMEX [CBV][M] 3 Min #8 | User order modification. Requested Price: 88.20. Requested Quantity: 1      Close  308  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:18:11.487886  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.20  Limit  309  1    Open  309  Simulated order modify complete      Close  308  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:20:07.144190  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.75  Stop  307  1    Open  307  Simulated order modify complete      Close  305  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:34:21.664314  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.75  Stop  307  1    Filled  307  Trade simulation fill. Bid: 87.75 Ask: 87.76 Last: 87.75  87.75  1  Close  305  2        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:34:21.664395  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.84  Limit  306  1    Pending Cancel  306  Canceling order due to sibling fill      Close  305  1        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:34:21.664437  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.84  Limit  306  1    Canceled  306  Simulated order canceled      Close  305  1        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:53:50.608905  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  87.41  Stop  310  1    Filled  310  Trade simulation fill. Bid: 87.45 Ask: 87.46 Last: 87.41  87.45  1  Close  308  1        MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:53:50.608983  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.20  Limit  309  1    Pending Cancel  309  Canceling order due to sibling fill      Close  308          MCL 2c.twconfig  0.00      Day
Orders  2022-01-28 11:53:50.609010  Sim1  [Sim]MCLH22_FUT_NYMEX  Sell  88.20  Limit  309  1    Canceled  309  Simulated order canceled      Close  308          MCL 2c.twconfig  0.00      Day
[2022-02-01 20:50:35]
This is where it is happening:
Make sure you are checking the correct Trade Window for the move to breakeven functionality set on a Stop Attached order. Refer to:
Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM
Date Time Of Last Edit: 2022-02-01 20:50:58
