Date/Time: Sat, 04 Jul 2026 22:29:27 +0000
MISSING STOCK DATA Intraday
View Count: 619
| [2022-01-24 04:29:46] |
| User403758 - Posts: 25 |
Hello! As you know I am using your Data Sevice, activated => "Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts". FUTURES work fine (I used them with realtime additional) with eod-data AND Intraday-ata. BUT: Stock Data are not supportet. I can access eod-data, yes. But Intraday-data last I one I get is from Sept 2021. Repreat, I dont neet Stock real-time data, but (delayed, 15min or so) Intraday I need. Why isnt it supportet with Denial ? Or do I somethingt wront. For example BTNX (Biontech): I only get Intraday data until SEPTEMBER 2021 Thanks, Alex |
| [2022-01-24 04:30:08] |
You cannot access this data when using CQG. You must use a separate installation of Sierra Chart and use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-24 04:31:20
