Date/Time: Wed, 23 Sep 2026 08:03:04 +0000
Change periodicity of chart in ACSIL on symbol change
View Count: 812
| [2022-01-23 23:16:35] |
| joshtrader - Posts: 569 |
I wrote some code which changes the periodicity, on a symbol change (it maintains a list of symbol to desired periodicity and changes to that). However, when changing the symbol, the chart fully loads, and only then does my study change the periodicity. What this means is that for a symbol change, two chart reloads are required. What would be the recommended way to change the periodicity before all the bars load? Is this possible? |
| [2022-01-23 23:23:57] |
You need to change both the symbol and the chart bar parameters at the same time. There should not be a problem with this we would expect.
| [2022-01-24 04:16:23] |
Thank you -- however, the signal to change the chart symbol comes externally, from clicking a quote board that is linked to the chart. That being the case, is there any way to avoid waiting for the chart to load all bars for the new symbol before I change the periodicity?
| [2022-01-24 04:32:55] |
No you cannot do this from ACSIL in this way. ACSIL must also be changing the symbol and the chart bar parameters all at the same time.
