Date/Time: Wed, 05 Mar 2025 19:46:29 +0000
Global Profit/Loss Management
View Count: 542
[2022-01-23 12:14:35] |
User645832 - Posts: 99 |
Hello, I wanted the platform to stop me out and not let me trade for the day once I reached a daily loss of $250. I did not work. My broker is AMP. Am I doing it wrong (see attached)? |
[2022-01-24 01:41:13] |
1+1=10 - Posts: 270 |
I'm a fellow user. In addition to what you've already entered you need to check "Lock After Positions Flattened", potentially "Disable Auto Trading on Lock" if you're using any automated methods, and "Flatten Positions When Loss Rules Met" Note the Status box in your picture: "Loss management is disabled. Account: 131324" The complete instructions for that window are here: Global Profit/Loss Management |
[2022-01-24 04:40:38] |
You also need to enable: "Flatten Positions When Loss Rules Met" Refer to: Global Profit/Loss Management: Daily Net Loss Management Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
