Date/Time: Wed, 05 Mar 2025 19:30:38 +0000
Bar Periods
View Count: 466
[2022-01-22 20:46:00] |
User957654 - Posts: 7 |
Hello, I was wondering if it would be possible to add 3 min bar periods to the live data exchange feeds?
[2022-01-22 21:03:56] |
This is already supported. You can change to any timeframe. Refer to: Changing Chart Bars Period Even down to 1 millisecond now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-22 21:04:19
[2022-01-22 21:08:31] |
Let me take a look. Thank you!
