Date/Time: Thu, 06 Mar 2025 03:29:25 +0000
Lack of "Line on High", "Line on Low" Graph Draw Types
View Count: 494
[2022-01-22 19:06:13] |
User847333 - Posts: 9 |
It's useful type of chart graph. How to draw this kind of chart? Thanks! |
[2022-01-23 16:14:12] |
ForgivingComputers.com - Posts: 1021 |
Use the Current Price Line Study, change the Input Data to High and the Subgraph Drawstyle to Line Extend To Edge. Duplicate and change the Input Data to Low for the "line on low".
[2022-01-25 00:38:47] |
John - SC Support - Posts: 38425 |
Another easier method is to use the Study Subgraph Reference and reference the High or Low and set the Subgraph to display as a line. Then you can set the Graph Draw Type to Blank. Refer to the following for the Study Subgraph Reference: Study Subgraph Reference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
